Nucleus One reboot after power failure
So, I can set a NUC to reboot after a power failure in Bios, but the Nucleus One doesn’t have that option.
Is there a reason why this isn’t an option? If I’m away, it means that Arc will stop working.
Hi @bevan_court,
I thought it was possible, did you check the BIOS options on the Nucleus?
(USB Keyboard and HDMI screen required.)
I tried it and couldn’t get access.
Auto restart is a mixed blessing .
I have my NUC set to it but my internet connection is way slower in starting than my NUC so I finish up with the NUC starting before my connection is made , so I finish up manually restarting the Roon software afterwards. if not you get the dreaded Metadata Improver failure
I hadn’t thought of that, but if written into the software, a small delay in rebooting could fix that.
In my case it can be as much as 3 minutes, not sure why it takes so long but it’s consistent.
I turn on power then brew coffee !! Then restart Roon server again
