I’m using a Nucleus Plus as my server. I am no longer able to see the server through any device. I cannot do a soft reboot because my computer can’t find the IP address. The Nucleus Plus is on (the power button lights up), and lights flash at the Ethernet connection, and at the other end of the Ethernet cable at my switch. I have tried multiple hard reboots, switching ports at the switch, and swapping Ethernet cables. No luck.
Can you please try to connect the Nucleus to a TV or monitor when it is in this state (powered on and Ethernet connected) and see if there’s anything displayed on the screen? If there is, please share a screenshot of what you see listed there, thanks!
Thanks for confirming. It is best to reach out to the RMA team in that case to get a ticket started for you, unfortunalty since there is no HDMI output, it sounds like we’re dealing with a hardware issue. Please complete the below form to get the case started, thank you.
