I just setup a Nucleus + Server. Got a Audioquest Vodka ethernet cable to connect to the network, got the HD Plex 200 W linear power supply, connected a hardrive using an Audiquest Carbon USB C cable. Sounds very good through my Cary DMS 600 (new) player “HOWEVER”, A USB drive connected directly to the Cary is
Much quieter
Wider soundstage
More clarity
Overall sounds better.
But the Cary info on artists etc is nowhere close and as convenient as Roon. I would prefer to use Roon and hence the investment but after having spent the money it seems I did not need to. The Nucleus has been broken in I think so I am not expecting much more improvement or can this be improved.
I am not tech savy but not understand a bit to get by. I have not played with any Roon DSP settings, can these help or will Roon never sound as good as a Player connected directly with a USB drive?
Any expert thoughts will be appreciated.
Manny
Interested in the response - I also have DMS 600 but using Roon core through QNAP Turbo app (which is also where the music is stored) Considering purchasing Nucleus as core.
Everything looks fine. With Roon and the Cary built in Ethernet bridge.
Whether your USB stick sounds better than Roon RAAT or not, can possibly be explained by the quality (or lack thereof) of the said ethernet bridge on your Cary.
It would be great if you want to experiment, and connect another Roon Ready streamer (via RAAT) to the Cary’s USB audio input, and play Roon via that.
Not sure sure what another Roon ready streamer to connect to the Cary USB would be. Please give me an example?
Can the the Roon be connected directly to the the Cary? Like either USB or are the USB ports on the server just inputs?
In my opinion the resolution bottleneck is probably my 20 port Netgear bridge which costs $50 more than the Ethernet bridge on the Cary.
The Cary DMS-600 cannot act as a “USB DAC” in the traditional sense. The Cary DMS-600 can act as a “USB Host” like you are using to browse connected USB drives, but not as an audio output for a connected computer.
Just to clarify, the Roon Nucleus USB connections can be used with a USB DAC. The Cary DMS-600 is not a USB DAC, so it will not work when used in this configuration.
