Nucleus+ power button illumination issue (ref#RV603K)
I need to replace the power button on a Nucleus +. The power button works but it no longer illuminates.
· The power button doesn’t illuminate. It use to emit a white light to indicate the unit was on. It no longer does that. The unit operates as designed…powers on the circuit. I can see that it can be replaced by removing the nut that secures it to the body on the inside & the wiring is plugged into a board that actuates the switch for power. I can replace it if I can obtain the part.
Hello @Kevin_Smith ,
We appreciate you writing in! Since the issue is Nucleus related, we kindly ask that you fill in our Nucleus hardware form:
