Nucleus Rev B not connecting to LAN after power outage (ref#0RL7SL)
Is Roon Server running?
· Roon Server is on, but I'm still having trouble connecting.
· "Waiting for your Roon Server"
What happens if you press the "Select a different Roon Server" button?
· I don't see Roon Server.
· *Nucleus*
After a power outage, my Roon Nucleus Rev B no longer connects to the network (LAN). On the rear panel, the right of the two LAN port LEDs is continuously blinking, while the left one remains steadily lit. Access to the web interface also does not appear to be possible.
We are operating a complex LANCOM network with approximately 50 devices connected via LAN and WLAN. Multiple LANCOM access points are deployed across different areas of the property. The Nucleus is located in the basement server room, where is it connected to a switch, which in return is connected to the main Lancom router. Internet connection is stable and fast
Good day @Nicci .
We are sorry to see you have this problem with your Nucleus.
Can you please try to connect the nucleus to HDMI and try to turn it on ?
Does the screen show anything ?
Also, if you hit ENTER , type ‘resetnetwork’ and press ENTER again, will it indicate nucleus in the network somehow ?
Do you see in the router’s admin panel that nucleus obtained some ip or visible ?
Regards.
What @alex_h means is to connect a monitor or a TV to the HDMI connector of the Nucleus and say what (if anything) appears on the screen…
And for this, you need to connect a USB keyboard to the Nucleus as well.
Hi,
Thank you for your help. The HDMI suggestion did get me into a menu, but resetting the network didn’t resolve the issue. Unfortunately, during the troubleshooting process I seem to have made things worse—I’m concerned I may have affected the boot sequence. The Nucleus is now completely unresponsive and doesn’t respond to anything.
At this point, I don’t believe there’s an easy repair. I’ll plan to order the new Titan within the next couple of days. To be honest, the Rev B Nucleus had also become a bit slow to respond over the past month and was starting to feel sluggish.
and sorry for the late reply
Hello @Nicci
Thanks for the report, and I’m sorry to hear you’ve hit some hardware issues with your Nucleus. The best next step here is to get in touch with our RMA department directly, as they’re in charge of all hardware-related Nucleus issues. To do so, open the Typeform link below and select ‘Other’ followed by 'This issue is related to a physical component".
Typeform link : Nucleus Troubleshooting
Screenshot for reference:
They’ll help get you sorted out moving forward. Thanks! :+1:
Hi @Nicci,
Our diagnostics servers indicate a new RoonServer machine is now associated with your account. We’re going to allow this topic thread to close at this point due to inactivity under the assumption that the original issue has now been resolved.
If you require assistance moving forward, simply reach out in a new tech support requestand we’ll promptly respond. Thank you!
