Is Roon Server running?
· "Waiting for your Roon Server"
What happens if you press the "Select a different Roon Server" button?
· I don't see Roon Server.
Please try to restart your Roon Server by closing the Roon app in the taskbar or rebooting your Roon Server machine.
· *Nucleus*
· *Powerline Adapters*
You mentioned powerline adapters in your network setup.
· I still can't see Roon Server even after bypassing powerline adatapter
Nucleus unresponsive after power outage at house–a quick Look online tells me that this is common but not addressed by Roon.
I had this same problem a year ago and there still does not seem to be a great solution.
last time, I thought I had a bad ethernet cable but really I believe I just got lucky that it showed up–turn on and off again enough times…maybe?
This is now happening every time the there is a power outage. Maybe a Roon Nucleus programming issue?
This is always asked, so: HDMI connection from Roon to tv screen tells me that there is, “no input”.
I have two Roon nucleus systems in different locations and have had Roon for 5+ years. I’ve got to say, I love the interface of the app, especially for the lyrics, but I have to spend too much time tinkering with the Nucleus.
Any help would be appreciated that doesn’t involve connecting a USB keyboard and start fixing code!
r
a network
