My Nucleus will not power on, and the network cable is flashing showing connectivity. When I press the power button and the network cable goes dark for a few seconds which I think means it is cycling.
Any suggestions?
Any suggestions?
I would suggest plugging a monitor and keyboard up to the PC and take/post a screen pic of what is showing on the monitor. That will let you know, if it is booting and what errors might be happening.
Thanks, I did not realize I could put a monitor on the nucleus. I realized I had mistakenly plugged the nucleus into an aggregated port, so this is resolved.
Thank you
