Nucleus won't power on despite adequate voltage from power pack (ref#N2XASG)
· Roon is slow, freezing or won’t start
· Roon won’t start up at all
· Nucleus won’t turn on. The power pack is putting out 19.2 volts. I have unplugged it for a day and tried restarting without success.
When I press the on button on the back it does not light up. The screen attached doesn’t show any activity on the Nucleus.
· Orbi RBRE960, no VPN
Hi @ken.keith,
Thank you for sharing the results of these diagnostics tests so far.
If you can’t access the web interface, don’t see any LED activity, and also can’t access any diagnostic screens when you attach the HDMI output to a display, then we’ll need to assess this unit on a bench for a hardware fault.
We’ll need to ask for a few specific details about this unit to proceed (serial number, etc). Please open the Typeform link below and select ‘Other’ followed by 'This issue is related to a physical component".
Typeform link : Nucleus Troubleshooting
Screenshot for reference:
We’ll follow up via email directly shortly after we’ve received the form. Thank you!
Hi @ken.keith,
We’ve received your inquiry and our hardware team will follow up shortly directly via email.
