Observation: Network problem and the solution
Just sharing as it can save you from harm, … maybe :innocent:
Experiencing a lot of drop outs on my AV network on one port while testing a streamer.
All other ports working as intended, at least i think so :wink:
There were/are no audible and visual anomalies experienced over time on other ports.
But, there were problems…!
The network configuration with problems:
1Gb/1Gb fiber uplink <-> MikroTik RB750GSi <-> Cisco 2940CG <-> Zyxel Gigabit switch unmanaged <-> Raspberry Pi 4 with vitos and ropieee.
This had massive dropouts resulting in connection loss and problems with audio.
At first i thought it was the RPi that was faulty or Vitos, so i tested with Ropieee.
The dropouts stayed, packet loss was at about 5%.
Packet loss on other ports was 0%, strange.
I had an extra Cisco 2940 1Gb uplink and 100Mb ports for testing that i replaced the Zyxel with.
After some configuration, i use VLANs, everything in place.
… no packet loss, music playing like it should, no drop outs.
This might be a compatibility issue with the RPi ethernet port and the Zyxel at 1Gb speed, but have not tested this, the Zyxel is not managed.
I did not test it with 2940 because it has no access ports with 1Gb.
Further testing will have to wait until i have an other switch in place.
On the Zyxel switch were also my H390, a Node2i and an Apple TV connected.
NEVER trust a (networking) device because it works so well, or have done so.
A stable network is paramount for a satisfying experience with Roon.
edit/
The Zyxel switch is a GS-105Bv3, had the RPi connected to the port labeled “high” as in priority.
Maybe the prioritizing feature is cause for the issue, not sure but it could be.
From the Roon Core to the Pi, it’s 1Gb → 100Mb → 1Gb - is my understanding correct? That is not ideal.
The “high” also looks suspicious. That might imply QoS that cannot be disabled, and that’s bad for problem diagnosis. I’d rather you use a normal unmanaged switch such as GS105 from Netgear.
Hi Peter,
My post is just to show that it is easy to blame Roon for a problem that is in the network.
The unmanaged Zyxel failed intermittently on one port and there was no obvious sign.
FYI, i am used to work with enterprise networking components and routed and routing protocols.
Managed switches and routers are not a problem for me and make my network a playground.
I have no issues with regards to SQ and stability.
Will not blame Roon if something is wrong, not before diagnosing the problem as not my fault :sunglasses:
Have now exchanged the Cisco 2940 with a MikroTik RB751G-2HnD with the AP disabled.
This MikroTik has a more conveniant form factor to hide behind the stereo.
The MikroTik RB751G-2HnD is actually a router with a switch chip.
Full switching via switch chip on all ports within my home VLAN.
Testing upload and download at 520Mb/s and 870Mb/s with a ping time 2ms average.
Measuring bandwith on the port the Ropieee is connected at 5Mb/s average, it will do.
Since this router is to be used as travel router/vpn it will be replaced with a hEX S.
MikroTik makes some interesting little but fast network devices.
