Nothing much to tell here
Generic USB DAC connected to the core on the Linux C2D Duo.
USB Centrance DacPort connected to the I7.
I’ve tried several albums compressed with Ogg Vorbis. When switching tracks there’s a click between them. The click varies in amplitude depending on the two tracks.
When playing the tracks on Foobar2000 the audio is completely gapless.
I’ve disabled all DSP and oversampling to make sure that the click isn’t coming from one of the modules - the click is still there.
Is the behavior the same for multiple endpoints or only for the Generic USB DAC? Are you able to reproduce this when using “System Output” if no other zone is available?
Also, can you please share the affected media via a private message as a Dropbox / Google Drive / Send.firefox.com link so I can take a closer look?
Thanks for sending those files over, I have created a ticket for you with our QA team who can take a closer look at this behavior. As soon as I hear back from them, I will be sure to let you know, thanks in advance for your patience!
Thanks for reaching out again and apologies about the delay in getting back to you here.
I wanted to touch base with some good news, which is that our technical team has been able to reproduce this behavior and we’ve opened up a bug report with our developers.
While I can’t say for certain when this bug will be fixed, getting things reproduced in-house is a critical first step, and I will keep this thread up to date as the team passes along feedback and work begins to get this resolved.
I took a look at our internal tracker today, and I can see that your ticket is still in our development queue. This means our developers are still planning to look at this, but we don’t yet have a timeframe for when that’s going to happen.
Once the ticket has been scheduled and work begins, I’ll have a better sense of timing here. Thanks in advance for your patience!
I’ve checked a few OGG files that I have and now I don’t hear the click when switching between tracks.
However, the playback is not gapless. But instead of having a short silence between tracks, there are missing samples.
I’ve verified this by:
generating a frequency sweep using Audacity.
Splitting the sweep into two wav files.
Encoding the wav files as ogg.
When playing back the wav files they sound as expected. When playing back the ogg files there’s a gap in the sweep.
When playing back the ogg files in foobar2000 they sound as expected.
Thanks for sending those over @maoravni! I have forwarded the link to QA and am awaiting further feedback from them, I will let you know once I hear back.
