· My DAC, streamer, or speaker doesn't appear as a Zone in Roon
· Connected directly to my RoonServer machine
· Yes, it shows up there, but it isn't Enabled
Does the "Enable" button unlock the Zone?
· I pressed Enable, but the Zone remains disabled
Since you are using a network connection to the device, please ensure that your RoonServer is on the same subnet as the device
· My devices are on a single subnet but is not visible to Roon
Try to disable any additional networking interfaces on your RoonServer machine.
· Disabling network interfaces had no change in behavior
Check to make sure RoonReady mode is selected on the device.
· I've checked this and the issue remains
· Only one output type is affected while the other output type works as expected
· after upgrading to windows 11
· lenovo laptop on windows 11
onboard audio device stuck on enabling
roon server on lan. laptop on wifi
