Core Machine
Dell i5-4570 3.20GHz, 32.0 GB ram, Windows 10 64bit, Roon 64bit installed, currently 1.8 build 795.
Network Details
Asus RT-AC68U, hard connection to core machine above, and a hard connection to one Roon Bridge, and a wifi to the other.
Audio Devices
To keep it simple (leaving out the iphone, ipad, and dell laptop - for testing purposes didn’t use them at all) I have two RoPieeeXL roon bridges both with khadas tone boards.
Library Size
141000 tracks
I like Roon, and really want it to work for me - there is so much about it that is far beyond every other music management application. I did the trial, dealt with a lot of crashing (looking at the logs it was due to something Roon didn’t like about specific files, so I quarantined them), and started with a month-to-month subscription. I had it installed on a central server, and the import had settled down and things seemed good. Unfortunately I ran into the ntdll.dll issue many people experienced and it was crashing multiple times a day. I let my subscription lapse, waited a bit (1.8 had only just come out), and just resubscribed (for a month). Happy to say, the ntdll.dll problem is gone, not though I don’t have any audio devices available for selection. When I go to “Audio” in settings, my two RobieeeXL’s are listed and I have enabled and configured them. If I reboot either, they drop from the list, then reappear. They are both updated to the current versions. Regardless, neither show up when I click “Manage Audio Devices”. When I select “About” from setting, both are also listed, saying I have the latest versions. Roon definitely sees them. But selecting is not an option.
Not to complicate the issue, but starting Roon on other devices will occasionally result in one of the bridges showing up for selection, but never both and never the device I started (iphone - 2020 se, ipad - mini, or laptop Dell Windows 10).
My latest log file is nothing but Debug: NotifyCorruptZoneDatabases and Error: [transport] emptying out corrupt zone database. What can I do to reset the zone database or clear out the incorrect records? I have tried deleting each audio item and doing a re-setup.
The one thing I haven’t done is completely uninstall and reinstall (large library, would like to avoid if possible). Is that my only option?
Thanks for any help you can offer and sorry, I know this is a repeat of a number of other threads.
