Hello, I see that there are 4 streams for BBC Radio 6 Music (AAC 320kbps, 128kbps, 96kbps, and 48kbps). Only the two lower quality streams will play. When I select either of the two higher quality streams, I receive a message “Playback was interrupted because a track failed to load”. Can anyone help with this? Thanks.
Are the higher rates are only available in the UK?
BBC 320kbps streams are definitely UK only. Not sure about 128kbps.
Those higher quality streams are indeed UK only. They weren’t advertised as such, but they are now.
Sorry for that!
I think that’s true for all BBC stations now?
I believe so.
Thanks all.
