I am trying to use the OSMC Remote Controller without any success.
Logs from dmesg (the hardware seems to be recognised):
[ 3.173229] usb 1-1.1.2: Manufacturer: OSMC Remote Controller
[ 3.194749] input: OSMC Remote Controller USB Keyboard Mouse as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.1/1-1.1.2/1-1.1.2:1.0/0003:2017:1688.0002/input/input1
[ 3.274304] hid-generic 0003:2017:1688.0002: input,hidraw1: USB HID v1.10 Keyboard [OSMC Remote Controller USB Keyboard Mouse] on usb-3f980000.usb-1.1.2/input0
[ 3.298372] input: OSMC Remote Controller USB Keyboard Mouse as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.1/1-1.1.2/1-1.1.2:1.1/0003:2017:1688.0003/input/input2
[ 3.362605] hid-generic 0003:2017:1688.0003: input,hidraw2: USB HID v1.10 Mouse [OSMC Remote Controller USB Keyboard Mouse] on usb-3f980000.usb-1.1.2/input1
[ 3.662364] usb 1-1.1.1: new high-speed USB device number 6 using dwc_otg
Thanks for the reply. I just send the feedback 1e402218c6985ab0.
BTW. The remote is working with my KODI an my PC setup. Thus, I am really sure there is something wrong with the PI running ropieee.
No I did not.
But now I did. Still not working. I did reboot server and ropieee twice.
I just generated a new feedback fb894ecc41dac69a.
I am really helpful for your effort.
I did some experiments. I tuned of WIFI and used a wired connection instead. Suddenly it is working. I am pretty sure that I did not change anything else (but who knows).
So far so good. But esentially only Play/ Pause/ Next is working. No volume control, even though DSP volume control is working using the roon app. Is this normal?
Just another feedback fae051ac743fa6c1. From my side we can close the thread.
Thanks for your greate service. I am really enyoing RoPieee.
@spockfish Iām facing an issue with an OSMC remote on Ropieee on one of my RPI setups. It does run with no issue on the other setups so the remote itself is working fine. The difference with the other ropieee setups is that this one does not have a display, only the usb remote dongle inserted. The OSMC dongle is recognized in Ropieee. Iāve sent a feedback e9521e9eafc7d86f. Iām at no clue why the remote does not trigger an action on this particular Ropieee setup.
Any help would be very much appreciated! Thanks in advance.
Hi @spockfish,
I tried it already thinking it could the issue but even as a single zone the OSMC remote does not trigger any actions.
On my other setups, having them grouped into a zone does not prevent from the OSMC to work, action is being applied to the entire group which would be expected.
I rebooted the unit as single zone, pressed a couple of buttons for actions and generated this feedback ba88913ec91cd840.
@spockfish A reflash did the trick. One possible option is that the OSMC dongle might not have been inserted at time of installation of Ropieee.
Thanks for all your help!
