OSX - Multichannel audio interface has no audio output
I’ve continued to have difficulty using my multichannel audio interface (Presonus StudioLive 16) with Roon in OSX. I’ve got the interface set up in the Audio/MIDI Settings using outputs 37 and 38. The “Test” function successfully outputs the test sound but no audio output from this same device from Roon. The settings within Roon seem to be accurate… the shuttle control shows that the song is playing… just no sound.
I had this problem when I initially started using Roon, got it sorted out but soon after started having trouble and I’ve just given up. Any help would be greatly appreciated.
Hi @Dylan_Gadwa ,
If you set these to channel 1 & channel 2, is there any change in behavior? What happens if you try to use the CoreAudio driver instead of the OS Mixer, does the behavior reproduce there too?
Unfortunately, I cannot use the channel 1 and channel 2 outputs on my audio device. Those jacks are XLR and I do not have the appropriate cables. When I use the CoreAudio driver (built-in speakers on my MacMini) there is no problem and I can hear audio output from Roon.
Hi @Dylan_Gadwa ,
If you try to use Roon’s MUSE (DSP Engine) to do a procedural EQ → Mix, are you by any chance able to configure left/right to channels 37/38 from that menu?
