Output playback issues contacting wrong device (ref#6LVT42)
Please try rebooting your router.
· No, I'm still having trouble
· Last week
· Silent Angel Z1+ server connected to T+A DAC 200
The system is not playing through the output. It seems to be trying to contact my computer rather than the roon core
Silent Angel Z1+ ,T+A 200 DAC
Hi David,
Fellow user here, trying to help. Have a few questions
  1. How is the T+A DAC connected to the Z1? USB?
  2. Could you post a screenshot of your Settings/Audio Page?
Hello @davidcornner,
Thanks for the details, and thanks @Rugby for jumping in. We checked your account, and there are two Roon Servers on it: one on your Silent Angel Z1+ and one on your computer. If the Roon app is connected to the server on your computer, you will only see that computer’s zones, and nothing will play through the T+A DAC 200 attached to the Z1+.
Please open Roon, go to Settings > General, and check which Roon Server it shows at the top. If it is your computer, please click Disconnect, then choose the Silent Angel Z1+ from the list. If you do not need Roon Server on the computer, please quit it there so the apps do not connect to it again by mistake. The section “You Moved Roon Server to a New Computer” in this article covers remotes that keep looking for the wrong server:
Once you are connected to the Z1+, the T+A DAC 200 should appear in Settings > Audio, grouped under the Z1+. If it shows there but is not enabled, please click Enable to turn it into a zone. This article walks through that screen:
If you are already connected to the Z1+ and the DAC is not listed, please post a screenshot of Settings > Audio as Rugby asked, and let us know how the DAC is connected (USB or network).
