HI. I have a Nucleus+ connected to an gigabit ethernet network. The nucleus has a 2tb internal storage SSD drive installed.
I had hoped to use my Synology 1511+ NAS as a source. The Synology is connected to the same ethernet network through a gigabit ethernet switch.
The roon nucleus can find the NAS and the shared folders. But it has extreme trouble scanning the files on the NAS. It indexes at most one new album per hour. It also won’t let me stop the scanning of the shared folder – just shows a spinning symbol and I cannot remove the NAS as a shared drive. After hours of trying to tweak this, restart all devices including the NAS, the nucleus plus, my room remote, etc., I gave up and reset the nucleus to start again.
This time I formatted the internal SSD drive and tried copying files from the NAS to the internal drive. This is working, but the speed is glacial. For the 13k tracks on the NAS, a total of 500GB, my Roon remote shows an estimated time for copying the files at more than 20 days. I’ve been letting it run for 12 hours now and it has copied about 200 tracks, about 8.5GB worth of data. Only 490GB left to go!
Do you have any suggestions for how I could diagnose why the ethernet connection is so slow?
Alternatively, is there any other way to connect the Roon Nucleus+ to the Synology NAS? The Synology does have USB connection for additional storage so I don’t know if some kind of direct USB connection between the two devices could at least allow for faster copying (I’d have to rearrange things considerably to do that because the Synology is not located in the same areas as the Nucleus+).
