When Roon is going to let us know the custom EQ settings we are using.In the same way that the song we are listening to is marked, the same can be done with the customizable EQ.It is very tedious to know in the EQ that you are…and it would be as easy as putting a check next to the one you’re using.Do something please, it would be very helpful. Thanks.
I’ve moved this to feature requests as it seems to be one.
