· *Only streaming* music is affected.
Please select the streaming service(s) with which you're encountering playback problems.
· TIDAL, Qobuz
Have you tried logging out and back in again to your streaming service in Roon Settings?
· Logging out and back in had no impact, the issue remains
· 30min ago
· HIFI Rose 150b / i5 intel NUC running roon rock
I was enjoying roon rock in my i5NUC but recently im experiencing an issue with play back. When i play a track in some cases in my streamer HIFI rose 150b shows the tack in playing but no sound from speakers. To overcome the problem i have to skip some tracks or select a different album. Any of you guys experiencing the same issue? Any suggestions would highly appreciated.
Thanks for sharing your report, and I’m sorry to hear you’re having issues with playback!
If you play audio from the system output of your Mac, do you run into the same issue? Or does it only happen when when you’re playing audio to your HIFI Rose?
As an immediate next step, can you please:
Safely stop Roon Server from running, and reboot your ROCK?
Reboot the HIFI Rose, and check that the firmware on the HIFI Rose is up to date.
If the above doesn’t help, could you please reproduce the issue and share the track name, and then please use the directions found here and send over a set of logs to our File Uploader?
If you haven’t yet, I’d power cycle the Rose as an immediate next step.
We were able to review a fresh diagnostic report from your Roon Server, and observed what Roon see’s in terms of volume level from the Rose, and according to Roon it’s showing the level to be at 99%. Here’s what we’re seeing:
