· 'rock' connected to ps audio directstream DAC. Setup has been functioning well over a year. Powered down for several days, and when started up it plays in something similar to 'scan' mode although there is no indication of such, mp3 instead of direct stream, and 28 second spans of music
· Ethernet to kinetic fiberoptic B7df00, to tp link archer ax55, to nuc sbnuc11, and ps audio BRIDGE II, no vpn
Glad to hear restoring the backup resolved the issue! Just to confirm - is everything working normally now on 2.66, or are you still seeing the scan mode behavior?
Great to hear everything is working! Just to clarify - restoring a backup does not downgrade your Roon version, you are still running 2.67. The “2.66” you saw was the version stamp on the backup file itself rather than the current server version.
The scan mode behavior you experienced was most likely caused by database corruption that occurred during the power-down. The backup restore cleared that and everything is back to normal.
