Playback issues with Roon using Merging Hapi at 384 KHz sample rate (ref#WVV3XB)
· I don't have a mesh network, but I use *managed network switches*
Your local network might need some re-arranging to support Roon.
· None of the suggestions have helped me. I'd like to submit a support request.
· Already described
I am using Tidal with Roon. My audio system consists of a merging Hapi, using merging MAD and Aneman configured in a 8 channel stereo configuration using Asio and Acourate room correction DSP. This configuration worked at 384 KHz sample rate with both, Audirvan plus and also Roon. But now I have problems playing music with Roon, although I didn’t change anything.
Answered before
If you have been using Audivana ensure it’s not locking on to the audio playback. Have you tried a reboot of the server machine?
Hi @Siegfried_Nitz,
Thanks for reaching out to us about this issue. I think the next step here is to enable some diagnostics on your account so our technical staff can get some more insight into what’s going on here.
