Well, it’s just a Chromecast Audio, fed via WiFi, with analog output to a little class-D amp, which is driving a pair of old Bell&Howell speakers.
Ah, do you mean the zone name? It’s the one called “CCA Library”. Bad this morning. Keeps stopping.
Hi @Bill_Janssen,
I spoke with the team about their analysis here and they were hoping we could try a couple things in order to better understand why you’re experiencing this behavior with the Chromecast Audio device.
When the device is next in this state where you’re experiencing these kinds of dropouts:
- Share a screenshot of the signal path
- Try using a different endpoint — Does it experience similar issues? Specifically, try using a local endpoint (not networked) if possible.
- Try disabling DSP settings and see if there is any change.
