Pls lose the Play from here / Remove / View parts menu
When clicking a queue entry to see the parts, the small window with choices looks somewhat out of place.
More intuitive would be a small V-shaped arrow to expand the parts, like I drafted in this screenshot. Expanding something is usually 1 click only and imo easy to achieve in this scenario.
For queue entries that don’t consists of parts, ie; normal tracks, the menu merely shows Play from here and Remove. Not really worth having a seperate menu for. I picture a small purple recycle bin on the right side next to the drag icon, which would replace the Remove choice hence makes the small menu obsolete. Clicking a line would then just start playing from there.
Agree this could be better.
Not that it is what you are looking for but you can go to “album editor” and under “edit album” select “disable multi-part composition grouping”. Not ideal but works to show parts (the individual tracks) in the queue without having to click twice. You do loose the easily identifiable division between movements… :slight_smile:
