· Very very high end system Focal Utopia headphones and DSD files really want to use Roon but the sound is awful. JRiver setup is perfect. Roon low sound and distortion.
· No server running on win10 only, don't use or need any remote connections
We went through the logs. Roon sends your DSD64 files to the HDV 820 ASIO driver as native DSD with no processing, and DSP is turned off, so nothing in Roon changes the signal before it reaches the driver. We cannot see what happens inside the driver and the HDV 820 itself, so we need a few details:
Please tell us whether the distortion happens only with DSD files or also with PCM files such as FLAC.
Please tell us whether JRiver is fully closed while you play in Roon.
Please tell us where you set the volume (the knob on the HDV 820, the Windows volume, or Roon), and roughly where it sits when the sound is low.
Please tell us how JRiver is set up to play DSD (ASIO or WASAPI, native DSD or conversion to PCM), since it sounds correct to you there.
