Does this happen for all endpoints? What if you play to a different device like System Output?
Your Core is a bit below our requirements. It’s hard to say if that’s the cause here, but just wanted to make a note that it could be a limiting factor for your performance.
I figured it out I think. Device doesn’t support MQA. I turned off Core MQA decoder and it stopped. Does that make any sense? It only occurs on the pecanpi endpoint. Note taken device specs. Thanks
