I had issues getting my Qudelix 5K to playback smoothly with RoPieeeXL but it worked fine on all other devices. I was already running via Ethernet but tried WiFi too and it made no difference (hence it was unlikely to be the USB + Ethernet bandwidth issues that some people talk about). I also tried these things with no change. I did not have the stuttering issue with a SoundBlaster 3 Play! that I tried, which means it was something specific to the Qudelix 5K.
As part of my troubleshooting I setup vanilla Raspberry Pi OS Lite setup and installed shairport-sync myself. At first the stuttering was even worse (faster and more choppy) that when using RoPieeeXL but after some searching around I found this which fixed the issue completely for me. Basically just leave the shareport-sync config as-is and setup /etc/asound.conf as follows (replacing the card # and hw: value with ones for your system, see link for how to get those). Note that I did not have to limit the rate to 48 khz for my Qudelix 5K on a Pi 3 B v1.2. I removed that line entirely and it worked fine.
pcm.!default {
type plug
slave.pcm {
type dmix
ipc_key 1024
slave {
pcm "hw:1"
rate 48000 # this line is only needed for USB DACs which only support 48khz
period_time 0
period_size 1920
buffer_size 19200
ctl.!default {
type hw
card 1
I don’t know if this will work in an RoPiee setup but it’s worth a shot for those having stuttering issues with USB DACs. I will attempt to test that later. If it does work @spockfish maybe some options can be added to the UI to apply this fix?
