Power Supply Issue with Roon Device (ref#3MSBLR)
Power Supply
LAN
Quick question. Considering the upgrade. Is the power supply needs of the Titan the same as the Nucleus Plus. I am using a filtered powered supply for my Nucleus Plus and want to make sure it will work with the Titan.
EC
Hi @Eduardo_Cruz,
We generally don’t recommend switching out the power supply that comes standard with the Nucleus. You can check if the specs for your custom power supply match those that ship with the Nucleus:
The Titan doesn’t have different power requirements than previous models - it would also ship with its own power supply, so you wouldn’t be required to mix/match and check polarity and voltage to have a working unit.
