Pro-Ject Stream Box RS Network Player
Hello,
I am trying to have my Roon Core connect to Pro-Ject Stream Box RS UPnP network player, but it cannot find the device anywhere on my network. Is that box not supported by Roon?
Best regards
Karl
UPnP is not supported by Roon.
Thank you Daniel, I should have known this.
It works via the uPnP/DLNA plugin on a LMS. However, I can‘t get the cover photo on the display of the Streambox RS.
