Hi there,
This evening I realized my Stream Box is connected at 100MB/s to my network.
Can anyone confirm that 100MB/s is the speed it supports or should it run at Gigabit?
Thanks for any feedback.
Hi there,
Most audio related gear only use 100mb ports this is very common. Audio doesn’t necessarily need 1gb it’s an extra expense.
Can confirm. The box does have a 100 mbit/s interface. And that’s already way more than needed for audio purposes.
Thank you for your feedback
