I am running the ROCK on an intel NUC, the software is up to date. Its working fine.
Archer router, feeding everything via Devolo wireline ethernet over power devices.
My problem is with a new Stream Box ultra S2. Its connected to my network via 180Mbits/sec ethernet over power. Wireless is off. Its feeding a Audiolab MDAC. I also have my ROCK feeding a Chord 2Qute direct via USB, which works fine.
The problem is that the Ultra shows up as a airplay device.
Is that as it should be? I thought it was a roon ready certified thing that Roon would recognise and interact with directly. It works fine, I can listen to music, it sound good, it is just that I was hoping for more than airplay.
The Ultra is running the latest version of its software.
