hi folks
i’ve been successful at connecting my kitsune red to a roon-ready dac.
i’ve been less than successful connecting it to a dac which is NOT roon-ready.
my current setup is as follows:
red → bifrost2 dac via USB (success streaming roon)
red → prism orpheus preamp/dac via toslink OR digital coax – NOT SUCCESSFUL
input to the red is via ethernet from the roon server.
i notice that when the bifrost dac is switched off i see the red appear in the roon audio devices list, but when it is on i see TWO red devices in the list. i’ve been assuming that with the bifrost off the one red device i see will connect over toslink or coax to the prism orpheus. this doesn’t work.
in any case, i can’t see how to get the red to send music to the orpheus.
i should note that the orpheus works properly when connected via optical or coax to a cd transport. that is, the optical and coax inputs work correctly in this case.
is there some additional setting i need to make in the config to give me the ability to stream to EITHER the bifrost dac OR to the prism orpheus? the only change i had to make to get the bifrost to work was to select the bifrost roon-ready option in the config.
i can send screenshots if that helps narrow down the problem.
thanks
