I’m having a problem again with Lumin showing on Roon audio zone. This time I rebooted the server Mac and the Mac Mini. I also rebooted Lumin.
Now I don’t even get the audio zone page.
All I get is "Remote Connection. Waiting for Remote Core…
What is going on?
Greg
(Greg Stratton)
#2
Hi Will,
Do you get a Select a Different Core button (or something like that)? If so, click it and select your core.
Cheers, Greg
Hi Greg,
I clicked on that, but it said “if you select a different core, you won’t be able to access the music you had before.”
I’m not sure what the implications of that really are? If it won’t effect my Tidal playlists, i guess I would be OK with that…
Greg
(Greg Stratton)
#4
Hi Will,
I had to do this with my android phone recently. No problems, it should just search for your current core.
Cheers, Greg
OK, thanks. Problem solved!
