I’ve moved your post to a new Support Request. Please give full details of your Roon and network setup, including who your ISP is, so that the Support team can help you further.
Thank you for your patience while we’ve diligently worked to reach every request for support with port forwarding. The diagnostics you’ve provided suggest that UPnP is enabled on your network, but your router is refusing the connection. This is either the result of UPnP not being enabled properly on your router, or settings at the level of your internet service provider.
First, to confirm the issue is not with your local network setup:
Try to enable UPnP/NATPMP in the web administration interface for the router directly upstream from your Core
Try to manually open the port in your router’s port forwarding configuration
Make sure the IP/Port matches the Port listed in Roon → Settings → ARC
Check for any VPNs or Firewalls that might be interfering
Check if your modem is in Bridge mode
If you continue to experience difficulties, we recommend reaching out to your internet service provider and passing along the following questions:
Have you implemented carrier-grade NAT for my account level?
Have you fully implemented IPv6, or do you have IPv4 addresses available?
Can I request a static IPv4 address to support port forwarding?
Are there any ports you have reserved at the ISP level I should be aware of?
Please, also let us know the following details about your setup:
Who is your internet service provider?
Please list the make and model of your modem and router?
Do you have any additional network hardware, like additional routers or managed switches?
Does your network have any VPNs, proxy servers, or enterprise-grade security?
What machine are you using as a Roon Core, and how is it connected to the internet?
There are also additional suggestions in our Port Forwarding Troubleshooting Article:
