help to solve the problem connect iTunes playlists. Everything is done in accordance with your recommendations. Screen shots attached. Roon scans the folder for a short time displayed the number of found tracks from iTunes, but once lost, and these tracks and playlists no where visible. Thanks in advance. Maxim
Your screenshots are lacking one important peace - we donβt know whether you enabled βImport iTunes contentβ feature in Roon. To do this you need to navigate to the Edit screen for the storage location where your iTunes XML is stored:
Then, enable iTunes Import
Also keep in mind that Roon uses the iTunes XML as a source for additional information about your files, and to support importing of playlists, but uses Roonβs folder-watching infrastructure to locate the actual files.
So, if This Mac/Gain/Users/Maxim/Music/iTunes contains only iTunes Music Library.XML and actual music files are located, for e.g., in This Mac/Gain/Users/Maxim/Foo, you need to copy iTunes XML into Foo folder and add it as a watched folder in Roon.
I do understand russian, but letβs keep it in english so others could participate in or benefit from this conversation.
Vladimir, thanks for the prompt answers.
But, I turned on the access of other apps to .xml file with iTunes. Checked that it is changed (date modified). Music files from iTunes from that playlist inside of this directory and I enabled βImport iTunes contentβ feature in Roon.
Do you have any playlists when you open a Playlists browser ? ( Press βTabβ to open side bar > Press βPlaylistsβ ) Can you also take a screenshot ?
I can see that 4 files were imported, how many files do you have in the iTunes folder in total ? Can you verify that iTunes folder contains more than 4 files ?
Files from βDay Breaksβ album have .m4p extension which Roon doesnβt support. iTunes was using such extension long time ago to sell media content with DRM protection.
Roon reads AAC and ALAC files in M4A container.
That is also the reason why those playlists arenβt shown, Roon ignores playlists which are empty ( in this case playlist is βemptyβ for Roon because it doesnβt detect M4P ). Note that playlist β25 most popularβ is shown, so iTunes integration is working.
