Hi. I have a problem with VAL 202 , Slovenia.
“Playback was interupted, because track failed to load”.
What can be reason? Others work as before.
Hello @ales_tomazevic , I can play that without problems.
Has it ever worked for you?
What are you running your core on? Is it a NAS?
Thanks for fast reply. In the past radio worked.
I have Roon on NAS (Synology DS718+). I have no idea what can be wrong. Some port on router? What can i try? (Both streams behave similar, the one with .m3u even shows logo, the other one drops before logo)
US region. I don’t have any issues streaming this station.
Hmm, have you updated your codecs? The NAS cores don’t normally come with aac codecs (MP3 is ok)
Can you play CJSW for instance - another aac station.
If you can’t play that, then you do need to update the codecs and this site will help
https://roononnas.org/en/synology-dsm7/
I looks like codes. CJSW also not working. Reinstaled ROON
inserted ffmpeg, still not working. Maybe i’m doing sth wrong.
Downloaded: ffmpeg-git-20230313-amd64-static, extracted, copied only file
ffmpeg to RoonOnNAS
Curent log:
19.03.23-21:52:34 — ROON_DATABASE_DIR: /var/packages/RoonServer/shares/RoonServer/RoonOnNAS
19.03.23-21:52:34 — ROON_DIR: /var/packages/RoonServer
19.03.23-21:52:34 — Model: DS718+
19.03.23-21:52:34 — Architecture: x86_64
19.03.23-21:52:34 — DSM Version: 7.1.1 (Update 4)
19.03.23-21:52:34 — PKG Version: 20220216
19.03.23-21:52:34 — Hostname: SynologyDS718
19.03.23-21:52:34 — MTU:
19.03.23-21:52:34 — ROON_DEBUG_ARGS: -noraatserver
19.03.23-21:52:34 — ffmpeg: /bin/ffmpeg
19.03.23-21:52:34 — RoonServer PID: 8528
########## Installed RoonServer Version ##########
200001234
2.0 (build 1234) production
production
What’s next ?
Does CJSW work now? If not then still some problem with codecs. We’ll ask for help from the Nas/codec expert.
If it does, then it’s the station. Although I can’t see what’s different about it compared to others.
CJSW doesn’t work.
Ok, pinging @crieke , he’s the guru.
You say things worked before - what has changed? Had you loaded ffmpeg before when things were working?
And I’m moving this to its own thread to make things clearer.
I think it worked at the begining. When Synology had dsm 6. Honesty … not sure any more.
Hi. I found the solution (mentioned in one post)
When defined ffmpg to execute, Val 202 started working. Also CJSW.
Well done. I assume you must have copied from a linux machine - I should have remembered that issue.
I found in this thread:
RoonServer is on USB external drive. Went to RoonOnNas\bin\ rightclick on ffmpeg - properties and added Excecute.
Hope this will help if someone will have similar problem.
