I have a Lampizator Atlantic Plus DAC connected to my Windows 10 playback PC via USB cable. I am using the SOTM TX-USBEXP USB card. I am powering the SOTM from an external HDPLEX linear PSU without any molex connected.
I installed the Amamero driver as per the Lampizator website, and in the Roon audio settings it appears as “Combo384 ASIO 1.03”.
When I try and enable this, I get the following error message:
Error: Error loading device info: DeviceInitFailed
EDIT: I tried the DAC in one of the standard USB ports, and it works in Roon. Any idea what is going on with my SOTM card?
EDIT 2: I reinstalled the SOTM driver and switched the USB cable back to that. Now I can still select the Combo384 driver in Roon and change the settings, but when I try to play a track I get a different error:
“Roon: An audio file is loading slowly. This may indicate a performance or hardware problem.”
