Hi, my first post here as a new user of Roon. Very happy with experience but have one issue.
I am using latest version of Roon via Rock on an intel NUC. Music streams without issue but I am having problems on all internet radios stations. After a few minutes playback stops. Is this currently an issue? On other non Roon devices internet Radio works without this issue.
Thanks for your reply and help.
It seems to happen on a number of stations typically BBC stations, Radio 6 music, Radio 3 and RTE radio stations. I have the codecs installed exactly as instructed on set up guide. The stations will will for uo to around five minutes and then suddenly stop. I’m streaming to a Bluesound node 2i which when I play the same stations from that device give no problems.
So that the team have all relevant information, please provide a brief description of your current setup using this link as a guide.
Make sure to describe your network configuration/topology, including any networking hardware currently in use, so they can have a clear understanding of how your devices are communicating.
I have tried streaming to a different end point (rasberry pi) and the problem persists, with Lyric FM and BBC radio stations. I have been checking my network and making some tests. I will post the requested information once I have tested a couple of other things (dns servers). Initially I did not have this problem streaming radio with roon. Thanks again!
Hi, just wanted to report back. I have changed the dns server on the core and given it a fixed IP address. This seems to have solved the problem, but I will test for another day or so, and will report back. Appreciate everybody’s help.
