@laurent_Desseille, I have moved your post to the #support category. While waiting for support, please complete the following template, and provide details of your ISP, modem / router make and model, and any other network equipment connected. Thanks.
<!-- Include your operating system and machine info (Model, CPU, RAM) -‐>
<!-- Write below this line -‐>
<!-- Your network gear (model of routers/switches) and if on WiFi/Ethernet, are you using YPN -‐>
<!-- Specify what devices you’re using and their connection types, like USB/HDMI/Chromecast, etc.) -‐>
<!-- Tell us how large your music library is, eg. “30,000 tracks” -‐>
<!-- Tell us about the problem you’re having in as much detail as possible. Screenshots are always appreciated! -‐>
Thank you for your patience while we’ve diligently worked to reach every request for support with port forwarding. The diagnostics you’ve provided suggest that UPnP is not properly configured on your router.
Please first try the following steps:
Try to enable UPnP/NATPMP in the web administration interface for the router directly upstream from your Core
Try to manually open the port in your router’s port forwarding configuration
Make sure the IP/Port matches the Port listed in Roon → Settings → ARC
Check for any VPNs or Firewalls that might be interfering
Check if your modem is in Bridge mode
If you continue to experience difficulties, please tag the support team and include the following information:
What is the make and model of your modem and router?
Do you have any additional network hardware, like additional routers or managed switches?
Who is your internet service provider and what is your geographic region?
Is your Modem configured in Bridge Mode so that it operates only as a modem or do you have the ports forwarded on both?
Know the problem has been solved. The status is READY to connect.
But when I launche the Roon ARC on my mobile phone : ONEPLUS 9 PRO, ROONARC is not connecting with my coreserver. The message on the screen is that I can only connect on private network.
