Hi, I bought an Allo USBridge with DietPi. I have heavily distorted audio on output via Roon, especially with higher sampling rates.
Due to a known bug in older kernel versions my T+A DAC8 needs at least kernel 4.9 or greater. It has a Tenor TE8802L USB chip and that has been fixed in recent linux kernel versions but is causing problems like the one I described in older versions.
Unfortunately dietpi is still on an older kernel. I treid with volumio, but volumio for sparky is also on an older kernel since they dont update as regularly as for raspberrypi. I then tried with a raspberry pi and RoPieee and that worked flawlessly since it had kernel 4.1.4. Unfortunately no RoPiee for Sprky as of yet :-(.
So to use my USBridge I need to update the kernel to a more recent version, can anyone help on how to do this or has had similar problems with roon and a SBC (Raspi, Sparky, etc.) and can help?
I know my way around linux a little, so commandline is not a problem. Please help, i am stuck here with a device with no use to me here.
Had this Avatar via Gravatar for ages. So it has been ripped off the original and not your avatar. The associated GIF is one of my all time favorites and a meme well known to those on the internet for more than 20 years like me.
Allo was asked about this old kernel for Sparky before. They are aware, but there was no answer when the new kernel will be ready for Sparky. I am afraid there is no workaround for now.
So any update on this @spockfish? I am sad to report that @allo.com has not been able to fix this problem with a usb-driver patch. I would be willing to sponsor the development of a ropieee for sparky, since it seems to be a problem finding a linux device with recent kernel except RPI3.
I have also owned an SMS200 by SOTM and it has the exact same issue with an ancient kernel being the source of the problem.
