I have been experiencing the same problem, and now one of my computers will not give me the authorization screen at all, it has been a few days…only my computer at work is connecting to Tidal and my home computer just isn’t connecting to tidal nor prompting me with the authorization screen.
Hi @Emiel_Bakker,
Often times this type of behavior is due to a firewall or antivirus blocking the connection to our servers — Can you try disabling any firewall and antivirus on the Core experiencing this issue and let us know if it helps?
