Hello, I have bought a lifetime version of a roon. Core is on a Nuc mini pc with Intel 7, 8GB RAM, the system is Debian. Until I upgraded the roon to version 1.7, I had no problems, after the roon upgrade I can’t see immediately after starting my Denafrips Terminator Dac, which is connected to usb. I need to refresh the audio roon tab several times to make it visible or to enter the cogs and press turn on again. Earlier, I had it on Ubuntu, after switching to Debian, this problem disappeared, unfortunately it returned after the upgrade to version 1.7. Is there an
Can you confirm that the firmware on this device is fully up to date?
Are other audio devices besides this one showing okay?
All software is the latest, until the upgrade to roon 1.7, everything worked fine
Do you have a Windows or Mac remote that you can connect this DAC to temporarily? Does it work normally when doing so?
