here is a snippet from the RoonServer_log.txt:
At first I boot the Ropieee and as you can se the Ropieee apiclient (the display) is connecting to the core. But the core does not allow the Ropieee endpoint to connect so there is nothing to display.
At 18.44.00 i pull the power to the Ropieee display and instantly the core discovers the endpoint and connects to it - but now i have no display/remote.
What has changed in the Roon core since it does not allow the endpoint to be connected when the display is on?
1/06 18:40:59 Info: [stats] 1577mb Virtual, 909mb Physical, 471mb Managed, 0 Handles, 70 Threads
01/06 18:41:14 Info: [stats] 1577mb Virtual, 909mb Physical, 472mb Managed, 0 Handles, 70 Threads
01/06 18:41:29 Info: [stats] 1577mb Virtual, 909mb Physical, 472mb Managed, 0 Handles, 70 Threads
01/06 18:41:44 Info: [stats] 1577mb Virtual, 909mb Physical, 472mb Managed, 0 Handles, 70 Threads
01/06 18:41:59 Info: [stats] 1577mb Virtual, 909mb Physical, 472mb Managed, 0 Handles, 70 Threads
01/06 18:42:07 Info: [roonapi] [apiclient 192.168.1.107:52722] connected (websocket)
01/06 18:42:07 Trace: [roonapi] [apiclient 192.168.1.107:52722] GOT com.roonlabs.registry:1/info
01/06 18:42:07 Trace: [roonapi] [apiclient 192.168.1.107:52722] COMPLETE Success {“core_id”:“ee9f416d-0e48-454d-95bc-062df3fd3596”,“display_name”:“roon-server”,“display_version”:“1.7 (build 710) stable”}
01/06 18:42:07 Trace: [roonapi] [apiclient 192.168.1.107:52722] GOT com.roonlabs.registry:1/register {“extension_id”:“org.ropieee.remote”,“display_name”:“RoPieee Remote Control V2 [ropieee]”,“display_version”:“3.020”,“publisher”:“Spockfish”,“email”:"htenberge+ropieee@gmail.com","required_servic$
01/06 18:42:07 Trace: [roonapi/registry] [org.ropieee.remote, RoPieee Remote Control V2 [ropieee] v3.020 by Spockfish htenberge+ropieee@gmail.com] is awaiting authorization
01/06 18:42:14 Info: [stats] 1577mb Virtual, 909mb Physical, 472mb Managed, 0 Handles, 70 Threads
01/06 18:42:29 Info: [stats] 1577mb Virtual, 909mb Physical, 472mb Managed, 0 Handles, 70 Threads
01/06 18:42:44 Info: [stats] 1577mb Virtual, 909mb Physical, 472mb Managed, 0 Handles, 70 Threads
01/06 18:42:59 Info: [stats] 1577mb Virtual, 909mb Physical, 472mb Managed, 0 Handles, 70 Threads
01/06 18:43:14 Info: [stats] 1577mb Virtual, 909mb Physical, 472mb Managed, 0 Handles, 70 Threads
01/06 18:43:29 Info: [stats] 1577mb Virtual, 909mb Physical, 472mb Managed, 0 Handles, 70 Threads
01/06 18:43:44 Info: [stats] 1577mb Virtual, 909mb Physical, 472mb Managed, 0 Handles, 70 Threads
01/06 18:44:00 Info: [stats] 1577mb Virtual, 909mb Physical, 472mb Managed, 0 Handles, 70 Threads
01/06 18:44:07 Trace: [raat] RAATServer discovered: RaatServer ropieee @ 192.168.1.107:40407
01/06 18:44:07 Info: [raatserver] GOT SERVER f846b474-0f1a-e13c-cd1b-2156504553c6::1ac8f1e0-9018-4bdc-ba41-646e7c8a22b2 @ 192.168.1.107:40407 ropieee PROTOVER=1 RAATVER=1.1.38
01/06 18:44:07 Trace: [push] restarting connection (Unable to read data from the transport connection: interrupted.)
01/06 18:44:07 Trace: [raatserver] [RaatServer ropieee @ 192.168.1.107:40407] connecting (attempt 1)
01/06 18:44:07 Trace: [push] retrying connection in 11893ms
01/06 18:44:07 Trace: [raatserver] [RaatServer ropieee @ 192.168.1.107:40407] connected
01/06 18:44:07 Trace: [rnet/RnetJsonClient] SENT {“request”:“enumerate_devices”,“subscription_id”:“0”}
01/06 18:44:07 Trace: [rnet/RnetJsonClient] GOT NONFINAL {“status”: “Success”, “devices”: [{“device_id”: “hw:CARD=sndrpihifiberry,DEV=0”, “type”: “alsa”, “config”: {“unique_id”: “50fb6250-1f8a-c2e7-3644-0a9ea862e54f”, “volume”: {“type”: “software”, “exclusive_mode”: null}, “output”: {“name”: "s$
01/06 18:44:07 Trace: [devicedb] [autodetect] No Match for DeviceAutodetectData[Type=Local Model=snd_rpi_hifiberry_dacplus]
01/06 18:44:07 Info: [raatserver] GOT DEVICE 1ac8f1e0-9018-4bdc-ba41-646e7c8a22b2::hw:CARD=sndrpihifiberry,DEV=0 Type=alsa Name=snd_rpi_hifiberry_dacplus
01/06 18:44:07 Trace: [rnet/RnetJsonClient] SENT {“request”:“enable_device”,“device_id”:“hw:CARD=sndrpihifiberry,DEV=0”,“subscription_id”:“1”}
01/06 18:44:07 Trace: [rnet/RnetJsonClient] GOT NONFINAL {“device”: {“discovery_data”: {“vendor”: “N/A”, “tcp_port”: 37665, “unique_id”: “50fb6250-1f8a-c2e7-3644-0a9ea862e54f”, “model”: “N/A”, “version”: “N/A”, “raat_version”: “1.1.38”, “protocol_version”: “3”}, “device_id”: "hw:CARD=sndrpihifi$
01/06 18:44:07 Info: [raatserver] [snd_rpi_hifiberry_dacplus] connecting (attempt 1)
01/06 18:44:07 Trace: [rnet/RnetJsonClient] GOT NONFINAL {“status”: “Success”}
01/06 18:44:07 Trace: [snd_rpi_hifiberry_dacplus] [raatclient] Initializing RAAT session
01/06 18:44:07 Trace: [snd_rpi_hifiberry_dacplus] [raatclient] Loading script raat.dat:base.lua as module base [1088 chars]
01/06 18:44:07 Trace: [snd_rpi_hifiberry_dacplus] [raatclient] Loading script raat.dat:dkjson.lua as module dkjson [22416 chars]
01/06 18:44:07 Trace: [snd_rpi_hifiberry_dacplus] [raatclient] Loading script raat.dat:protocol.lua as module protocol [2045 chars]
01/06 18:44:07 Trace: [snd_rpi_hifiberry_dacplus] [raatclient] Loading script raat.dat:roon_tcp.lua [43475 chars]
01/06 18:44:07 Trace: [snd_rpi_hifiberry_dacplus] [raatclient] RAAT Session initialized in 119ms
01/06 18:44:07 Trace: [snd_rpi_hifiberry_dacplus] [raatclient] SENT [2]{“request”:“info”}
01/06 18:44:07 Trace: [snd_rpi_hifiberry_dacplus] [raatclient] SENT [3]{“request”:“set_client_type”,“client_type”:“Roon”}
01/06 18:44:07 Trace: [snd_rpi_hifiberry_dacplus] [raatclient] GOT [2] {“transport”:{“is_supported”:false,“info”:[]},“flags”:{“has_write_chmap”:true},“status”:“Success”,“info”:{“unique_id”:“50fb6250-1f8a-c2e7-3644-0a9ea862e54f”},“volume”:{“is_supported”:true,“info”:{“supports_dsd”:false,"config$
01/06 18:44:07 Trace: [raatserver] [snd_rpi_hifiberry_dacplus] connected
01/06 18:44:07 Info: [transport] creating endpoint for raat device 50fb6250-1f8a-c2e7-3644-0a9ea862e54f
01/06 18:44:07 Trace: [snd_rpi_hifiberry_dacplus] [raatclient] SENT [4]{“request”:“subscribe_transport”}
01/06 18:44:07 Debug: AudioDeviceMunge.GetManufacturer(AudioDeviceType.Local, “”, “snd_rpi_hifiberry_dacplus”, “”, “”) => “HiFiBerry”;
01/06 18:44:07 Debug: AudioDeviceMunge.GetModel(AudioDeviceType.Local, “”, “snd_rpi_hifiberry_dacplus”, “”, “”) => (null);
01/06 18:44:07 Trace: [snd_rpi_hifiberry_dacplus] [raatclient] GOT [3] {“status”:“Success”}
01/06 18:44:07 Debug: AudioDeviceMunge.GetManufacturer(AudioDeviceType.Local, “”, “snd_rpi_hifiberry_dacplus”, “snd_rpi_hifiberry_dacplus”, “”) => “HiFiBerry”;
01/06 18:44:07 Debug: AudioDeviceMunge.GetModel(AudioDeviceType.Local, “”, “snd_rpi_hifiberry_dacplus”, “snd_rpi_hifiberry_dacplus”, “”) => (null);
01/06 18:44:07 Trace: [snd_rpi_hifiberry_dacplus] [raatclient] SENT [5]{“request”:“subscribe_controls”,“controller_id”:“ee9f416d-0e48-454d-95bc-062df3fd3596”}
01/06 18:44:07 Trace: [snd_rpi_hifiberry_dacplus] [raatclient] GOT [5] {“action”:“Changed”,“status”:“Success”,“controls”:{“volume”:{“mute”:false,“value”:0,“min”:-80.0,“info”:{“supports_dsd”:false,“config”:{“type”:“software”},“requires_external_persistence”:true},“type”:“db”,“step”:1.0,“max”:0.0$
01/06 18:44:07 Trace: [dspengine] loaded DSP config {“version”:3,“items”:[{“type”:“bs2b”,“enabled”:false},{“type”:“parametric_equalizer”,“enabled”:false},{“type”:“audeze_presets”,“enabled”:false},{“type”:“speaker_setup”,“enabled”:false}],“headroom_adjustment”:{“type”:“headroom_adjustment”,"enab$
01/06 18:44:07 Trace: [transport/audeze] picking preset lowlatency
01/06 18:44:07 Trace: [transport/audeze] picked null preset!
01/06 18:44:07 Trace: [zone stuen] Loading
01/06 18:44:07 Trace: [zone stuen] Suspend
01/06 18:44:07 Info: [zone stuen] Canceling Pending Sleep
01/06 18:44:07 Trace: [stuen] [zoneplayer/raat] Endpoint snd_rpi_hifiberry_dacplus Initial State: Idle
01/06 18:44:07 Info: [transport] created zone stuen
01/06 18:44:07 Info: [transport] with endpoint snd_rpi_hifiberry_dacplus (23:1:50fb6250-1f8a-c2e7-3644-0a9ea862e54f) [IsAvailable=True]
01/06 18:44:07 Trace: [stuen] [Inactive] [STOPPED @ 0:00]
