Hello.
Could you help me with adding a new radio station? There is a link to streaming: https://stream.rcs.revma.com/ye5kghkgcm0uv
When I try to paste it during manually adding a new station, there is an information that Roon didn’t find any station.
Problem solved. I’ve jus found a direct stream link: https://stream.rcs.revma.com/ye5kghkgcm0uv
Hello @Marcin_Pacyna, I’ve had a look at that stream. It redirects and adds a token before going to the audio server. This causes problems for Roon which doesn’t seem to pick up the token.
If you add it explicitly (as you did with your second link) then things are OK.
I could add the station to the main Roon database with an explicit token but I’m hesitant because I don’t know if the token is time limited.
I would be grateful if you could let me know if Radio 357 continues to work for you.
In the meantime I’ll bring the problem to Roon’s attention.
Hello. It stopped work. I turned on another radio and when I was trying to play Radio 357 again it doesn’t work. I cancelled it and try to add it again with this second link, but it doesn’t work.
I tried again and it works again…
They start broadcasting today and they say that they are waiting for approval from TuneIn:
It may not last again…
I have added the http stream instead and that works.
Search for Radio 357
Oh, thank you. I’ve just added it and it works! Thanks!
