Macbook Retina
Virgin Media Modem
Asus AC68 Router
Netgear Switch
Qnap 453DX NAS (Roon Core)
Everything on ethernet, apart from Macbook
Naim Muso Gen 1 (Ethernet)
Naim Muso QB Gen 2 (Wifi)
When activating the Musos through Roon, using Airplay, the Musos come on at full driver damaging volume.
Naim have noted this issue is with Roon and not them, however they have offered that if you get in touch with them, they can work with you to find a solution.
This isnt practical, but sure, it is a temporary fix to ensure no damage is caused to the drivers.
I have to set it low enough so that it dosen’t come on loud, then have to go into the NAIM app to go louder, when the volume control in ROON works fine. There is no NAIM app for a Macbook for example, where I operate Roon from normally.
It’s quite silly for what is effectively £3k’s worth of hardware and software.
I’d prefer it just gets fixed, it isn’t anything complicated I’m told.
Yes thats a fair point and I appreciate the suggestion, but Im not too interested in paying $250 to make the $1500 Muso work like it did before Room/Naim broke it
Plus, I have one box solutions for a reason…one box.
Just waiting to get some support on this from Roon support, I figured this is how the support tickets work?
To be honest Naims track record of late has not been great. With each firmware upgrade they break something. I had my Uniti Atom go to 100% after the last firmware upgrade. I could see the volume rising all on it’s own. Not the only one to. So I would say from evidence this is a Naim issue.
