I tried upsampling within the DSP settings and it didn’t go well. (I am using the latest version of Roon)
If I turn on sample rate conversion and choose either Max PCM Rate or Max PCM Rate (Power of 2), I get no music and low level crackling. If I go to the custom settings and set 44.1 to be converted to 88.2, this works but no higher conversion will. This was tried with a 44.1 ALAC file. Roon is recognising the speakers in device settings as having 24/192 capabilities.
My Core is a 2012 Mac mini i7 2.3 server connected to the router via ethernet. The LS50w are connected to the network via wifi but I get a fast, strong wifi signal to the speaker location.
I want to continue to use wifi rather than using additional ethernet cables to the speakers.
Are you able to give me any pointers as to why anything over 88.2 is causing this problem?
What is the sampling rate of the LS50W? Depending on the source, the LS50W uses a sample rate of 192kHz (for USB Type-B audio) or 96kHz for the optical TOSLINK input.
I believe WiFi has the same or similar restrictions I cannot currently find the relevant document.
That assumes the WiFi input supports 192? maybe it does I am not sure, as a quick test connect a temporary lan cable from your router to the LS50w’s and see what resolution Roon sends, I have just tried it on mine and 192 streams as 192 via a lan cable.
I would give the Ethernet cable a try because even as a temporary test, it would give us a great data point. We also have some additional suggestions in our KEF Troubleshooting Documentation.
I am currently listening to an internet radio station by streaming over WiFi from my Nucleus server to my KEF LS50W’s. I just changed the upsampling to 192 kHz and it’s working just fine.
Doesn’t solve the problem, but I can confirm that upsampling via Roon to 192 kHz over WiFi to the LS50W’s does in fact work.
I had been listening by upsampling to 88.2 kHz before reading this thread, and can honestly say that I don’t hear any audible difference bumping it up to 192 kHz. YMMV of course…
I stream wirelessly to my Kefs at 192/24, no problems. However… my speakers are only a metre or so from my router and, I chose a WiFi channel on my router that is free of congestion from neighbours.
To do this, I used “iStumbler” on a Mac to see what channels all my neighbours were on. Then I manually logged into my router and chose a different channel.
You can use “NetStumbler” on a PC to do a scan.
You say you use “Google WiFi” so you can’t choose whether you’re on 5GHz or 2.4, I guess you can’t choose channel either then?
What Router do you have? How come you can’t log into it?
I use a Virgin router that was supplied free with my cable broadband. Google wifi selects band and channel automatically. I don’t think I can manually change either.
I could try Ethernet as a test but it’s a pain and I’d have to use it via power line from an inconvenient position.
Ah ok… so your Virgin Hub is just being used as a modem and Ethernet router, not providing Wi-Fi
In that case you need to find a way of logging in to the Google Wi-Fi base stations maybe…?
Might be worth doing a netstumble and see what WiFi channels are being used locally. Then, if you can find a way to manually control the Googles it may help.
Have you thought of maybe getting another google base station and putting it nearer to the Kefs?
Hmm… I’ve had a quick Google of the Google Wifi system… seems you can’t log into it.
Looks like you might have to go down the power line route.
Couple of things you could try…
Hard wiring the google puck closest to the virgin router if you haven’t already done so.
Setting up the Virgin Router to only use 2.4 GHz. 2.4 GHz travels through walls better than 5G. You may then be able to log into the Kefs and force them to log into the virgin WiFi signal rather than the Google WiFi signal.
You can log into the Kefs by typing in their assigned IP address.
Just thoughts really… these ideas may or may not work!!
Thanks for your effort and suggestions. I think Ethernet over power line is the best start. I’m happy with 44.1 but it would be reassuring to see 192 work and see if it sounds any different.
I use up-sampling all the time. I’ve convinced myself it sounds smoother and more ‘Analogue’ like.
I stumbled across a post that suggested up-sampling MQA on a non-MQA DAC improved things so I tried it and I felt it improved CD quality masters as well. It’s subtle, but it’s there!
I use Smooth/Minimum phase up-sampling to 192/24 and I think the Kefs sound, as I say… smoother and more analogue like, with less of a clinical ‘edge’ if you see what I mean?
Anyway… worth a try.
I also have a few hundred gigs worth of actual ‘HD’ recordings, some DSD which get sampled to 192/24. They sound fine.
