I have the same problem.
Router -> Innuos ZENith. Problem with Tidal integration after making Roon Update. Please resolve this issue asap.
Thank you.
What kind of router are you using?
What kind of remote device are you using to try to log in? What browser? Is there any change if you use a different remote?
I use Asus RT-N12+ B1 router and Ipad Air I as remote. Not a chance, yesterday all worked just fine, after update the problem has appeared.
tomasz
check my post here
i had similar issue, but was able to resolve after complete log off / log on from tidal
make sure your Tidal pops up with the new login for Roon + Tidal activation
and make sure your tidal library synch has completed…
I got the same problem after updating yesterday. Router–>innuos Zenith se as core. Remote iPad or Samsung Galaxy - Makes no difference. Login/Logout Tidal doesn‘t help. Disabling/enabling Roon on Core, restarting - unfortunately nothing works, still the Same bug.
Would be thankful for help and/or fixing
Router is a FritzBox
I also got the same problem now again, and i have had the problem before where i had to reinstall everything. I dont want to use Roon anymore. It has too many bugs
Same problem here on v528. Took a few Tidal logins and reboots of the controller and the ROCK to resolve.
I gave the same issue.
Linked to an Antipodes EX (own internal dac) from windows laptops via Linksys router.
Same issue of perpetuate state of ‘synching library’ after update. Logged off/on Roon last night and things seemed ok.
Until today whilst playing a playlist (two song in) after the second song finished, nothing.
Looking at Roon it seemed to be searching for the next song with no luck. Click forward a couple of time. Same thing. Then got the message playlist had been deleted.
Logged off/on Roon. Same thing still happening (trying other playlists).
Rebooted Antipodes. Things working again.
Playlist still there
