Hi. Same problem from Spain using qobuz.
reinstalled version 1.7, still didnât work. Removed from my old Mac and set up a new core on a MacBook Air running Monterey and now works fine. Moral of the story, donât update as the money grabbing tech companies use it as a mechanism to create obsolescence and force more cash outlay.
Youâre right, I was focusing on the wrong IP. I saw qobuz.com in the DNS answer and followed that by mistake.
When I followed the correct stream, I saw a very similar cipher suite offer by my client (itâs identical to the one in the first image I shared that has the client Hello). But, there is no Server Hello. The server goes right to âClose Notifyâ and sends a FIN/ACK terminating the TCP Session.
Unfortunately it appears as if Server 2012R2 does not have the appropriate cipher suite support to establish a TLS/SSL session to Qobuzâs cloud infrastructure that is hosted on Amazonâs Cloudfront. Iâm also 99% certain that Server 2012 (not R2), Windows 8, Windows 8.1, Windows 7 - will not support Roonâs Qobuz integration.
In summary, it appears that Qobuz on Roon will not work (out of the box) with the following operating systems:
- Windows Server 2012 R2
- Windows Server 2012 (not R2)
- Windows 8
- Windows 8.1
- Windows 7
- Donât even ask about XP
Since Roon is using the Operating Systemâs ciphers through WinHTTP API calls, it is at the mercy of what the Operating System has installed. Despite the article I pointed to that shows Windows Update adding new ciphers, the correct mix of Key Exchange, Authentication, Cipher and Hash are not supported out-of-the-box that would allow Roon to communicate with Qobuzâs online streaming servers. The OS does support those individual Ciphers/Hashes, but the right combination must be supported in order and that does not appear to be the âout of boxâ configuration. There may be a way to change this either through Group Policy or Registry settings however I do not know the answer at this time.
Those who went to sites like Qualysâ SSL Labs (https://www.ssllabs.com/) to examine their Web Browserâs supported cipher suites should know that what they see is not the cipher suite that the OS has built-in. What theyâre seeing is the cipher suite that the Web Browser has built-in. Google Chrome and Firefox use their own SSL/TLS Cipher Suites as they have their own SSL/TLS implementation. This ensures that insecure algorithms are not used and allows older Operating Systems to be used past their end of life. YMMV on MACOS and Linux.
Iâll continue researching what I can and will post back here. In the meantime, Iâll be installing ROCK on a spare NUC.
Additional Information For Those Interested In Researching Further:
This more specifically lays out cipher suites supported by Windows 8.1 and Server 2012R2:
This lays out the ciphers that Windows Update added:
https://support.microsoft.com/en-us/topic/update-adds-new-tls-cipher-suites-and-changes-cipher-suite-priorities-in-windows-8-1-and-windows-server-2012-r2-8e395e43-c8ef-27d8-b60c-0fc57d526d94
This explains cipher suites:
@Steven_Marshall - What was the older version of MacOS you were running where Roon wouldnât stream Qobuz ?
Yosemite 10.10.5, worked perfectly until Roon told us all to upgrade to release 1.8 which had the TLS 1.2 handshake and there is no way to upgrade 10.10.5 to the TLS 1.2
I migrated my Roon Core from Win7 to a Linux VM running on the same Win7 Host. No issue so far. Qobuz is playing fine.
Iâm also running MacOS 10.10.5 (Yosemite) and downloaded Monterey but havenât installed it yet. As far as I can tell the only way to get from MacOS Yosemite to Monterey is to do a new installation which will mean setting up applications, etc. all over again. Not happy about this.
I did give a try to enabling the TLS 1.2 client proto on my Windows 7 machine, but it didnât fix the issue. Puts a damper on my Qobuz trial unless I find another place to run it I guess.
Aa fascinating as all the techy packets, pings and Cipers talk is
Presumably there are now a lot of Qobuz Via roon users (like me) for whom it hasnât worked in almost a week.
In laymanâs terms, for Qobuz usage what are the min specs for Roon Core. Win10 Iâm presuming? And the endpoint thingy, I presume itâll be immune to this problem as long as the core is workingâŚ?
In the end, where is the problem, what can we do if we want QOBUZ via ROON?
Not being a cypher packet ping man myself, the only way I could get the blooming thing to work was set it up on an new computer. Basically, I believe the recent upgrade rendered the previous way that these packets cyphers and pings talked with each other between Qobuz and Roon unable to talk to each other on older machines (like mine), which can no longer be upgraded to speak new ping, cypher or packet. then you have to work out if you can teach it a new language or get different kitâŚeven though your old machine might be rock solid
Hi all, weâve been in touch with the Qobuz team and they just rolled out an update that should resolve this â can you all try again and let me know if itâs working?
Yes! It does seem to be working initially for me, I queued a track and it played. Hope it sticks, hope others have success. Thanks for providing the solution! Core running on Windows 7.
Yesss, it works here in France.
Fingers crossed!
Do we need to restart Qobuz?
Nope, just try playing some Qobuz content in Roon.
no, it works well now
Itâs working for me now!! Yay!
Unfortunately I have already built out a ROCK server. Now Iâm wondering if thatâs a better solution than running Roon Server on Windows Server 2012 R2
Definitely give ROCK a spin, I think youâll really love it. Regardless, glad youâre up and running! And thanks so much for the Wireshark sleuthing yesterday, it was a big help.
