John_Veale
(John Veale)
February 25, 2021, 6:49am
1
Mac Mini OS X System info/Roon 1.8)**
When I play a 24/96 file, the signal path is as follows:
The node 2i is connected directly to my Meridian D6000 digital speakers which accept a 96/24 digital coax signal.
My question is:
Why it the signal going through bit depth and sample rate conversions? This degrades the signal.
Because you have it hooked up using the airplay protocol which has a max of 44 16. Look in roon settings, audio for the 2i with RAAT connection.
RTaylor3rd
(Rudy Taylor)
February 25, 2021, 7:31am
3
is there a way by which you can hide the airplay access leaving google cast and raat only?
John_Veale
(John Veale)
February 25, 2021, 8:17am
5
Thank you for your reply. Unfortunately, I don’t know how to change the audio output for the 2i. I have tried going into settings/audio on Roon, but I don’t see a way of changing from the current output of the 2i as airplay to whatever it should be. I would appreciate any detailed help you could give me.
Thanks in advance.
Post screenshots of the settings audio.
John_Veale
(John Veale)
February 25, 2021, 9:41am
7
I have managed to sort it out. Thanks.
beka
February 26, 2021, 10:32pm
8
Hey @John_Veale , thanks so much for posting about this and engaging with our community to find a fix. Glad it worked!
@ged_hickman1 thanks for your help. We’re grateful
system
(system)
Closed
February 28, 2021, 10:32am
9
