I use ROON several years ago. After I switch to 2.0 my hi-res files and DSD files doesn’t play well. In the setting I saw that there is no possibility for 24-192 files??!!??
Before 2.0 everything work perfectly !
Correct me if I am wrong!
Welcome to community, @Vlasta. I have moved your post to the #support category so it is visible to Roon support.
So you may be assisted, please complete the support template below, and describe the problem using examples and screenshots. Thanks.
<!‐-Include your operating system and machine info (Model, CPU, RAM)-‐>
<!‐-Write below this line-‐>
<!‐-Your network gear (model of routers/switches) and if on WiFi/Ethernet, are you using VP-‐>
<!‐-Specify what devices you’re using and their connection types, like USB/HDMI/Chromecast, etc.)-‐>
<!‐-Tell us how large your music library is, eg. “30,000 tracks”-‐>
<!-‐Tell us about the problem you’re having in as much detail as possible. Screenshots are always appreciated!-‐>
First of all , Thank you ! @mjw
Here is my data :
MacOS Catalina 10.15.7 , iMac Late 2015, 1,6 GHz Dual-Core Intel Core i5, 8 GB 1867 MHz DDR3
NAS Qnap 451 P2, 4 GB RAM
sOTM SMS-200 SE is connected with NAS throw ethernet cable, from SMS-200 SE to MYTEK Liberty with USB cables and sOTM tX-USB filter
18000 tracks
After I move to Roon 2.0 I lost possibility to correctly play my hi-res files (24/96, 24/192, MQA192 ). The sound was creaking and rustling…but I can play 24/88, 24/176 and DSD64 fine. I am little bit confused…
And also, maybe I’m subjective , but I think that sound was little better on roon 1.8
[/quote]
Thank you in advance !
