I’ve just hit a few problems trying to setup my ROCK based Roon system at work. ROCK is running fine on the new Intel i7 NUC.
I decided to resurrect an old Acer EeePC netbook running Windows 7 to use as a Roon control and to copy files onto the music library USB drive on the ROCK. Roon won’t run because the netbook doesn’t support OpenGL. Bugger!
So I then moved to the Apple iPad 32GB model MD514X/A I was planning to use as the main Control device with this system. It’s running iOS 10.3.3 as its up-to-date OS. Roon won’t install because it needs iOS 11. Bugger!
Time for a rethink. Or can someone suggest some workarounds?
